Deletes the loopback port from the specified member VLAN.
| vlan_name | Specifies the name of the member VLAN from which you want to delete the loopback port. |
N/A.
This command disables and deletes the loopback port from the specified member VLAN. This command does not delete the member VLAN.
The following example deletes the loopback port from the member VLAN leafvlan:
configure leafvlan vlan-translation delete loopback-port
This command is available on all platforms that support the VLAN Translation feature. For features and the platforms that support them, see the Switch Engine v33.1.1 Licensing Guide document.
